TwinTurbo.NET: Nissan 300ZX forum - look for the following when taking pictures...
Subject look for the following when taking pictures...
Posted by beanz on April 23, 2008 at 11:18 PM
  This message has been viewed 122 times.
In Reply To Re: sounds like a Blitz boost controller solenoid posted by msmith on April 23, 2008 at 02:57 PM
Message in order to figure out what's going on with your configuration, when you take pics:
* trace where the teed vacuum lines are running to -- unless things are just totally wack, you should find yourself tracing them to the intake and the wastegates
* trace where the electrical lead coming off the solenoid goes to -- it should be run to the brains of the unit (a small box) if they're still around -- the cabin display unit hangs off the brains too
* try to see if the stock boost solenoids are connected or disconnected both in terms of vacuum and their electrical harnesses/connectors (check out the boost controller install tech for help finding these)
andrew davidoff
